Lower temp fan switch part number
Old Jul 26, 2008 | 04:49 PM
Tims91RS's Avatar
I just broke my Jet fan swith which turns the fan on earlier than the stock one did. Does anyone have a part number for this that I can get from a parts store. Or another Gm application that will work to turn the fan on at 195.
Old Jul 27, 2008 | 12:09 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Lower temp fan switch part number
Hypertech fan switch "HYP-4028" (200°/185°)
Old Jul 27, 2008 | 12:47 AM
TheTrooper70's Avatar
I need a parts number too.
i would really like to find a 195 not a 200 if i can. Living in arizona my 85 iroc heats up fast and my fan does not turn on fast enough (i have the stock switch in there.)
a part number would be great. Thanks!
Old Jul 27, 2008 | 10:07 AM
Tims91RS's Avatar
I was thinking a of a cheaper switch available from a local auto parts store. The hypertech ones are like $50.
Old Jul 30, 2008 | 12:51 AM
4ormula's Avatar
Car: 1989 Pontiac Formula 350(Maui Blue)
Engine: 355 TPI,accell superram,full roller
Transmission: Street/strip 700R4
Axle/Gears: Australian 9, 3:27 ratio
I just recently installed a hypertech fan contrller sensor and mushroom conector harness on my 89 350 tpi. I drove to jegs in Columbus, Ohio and bought it.
The part number is hypertech #4026.
Fans on at: 176 degrees off at 166 degrees.
My modified tpi setup used to run in traffic with ac running up to 235-240, now runs 210 at the most. It is the best $45 part I have put on my car in a long time.
Hope this helps,
Joe
Old Jul 30, 2008 | 01:46 PM
Stephen's Avatar
Car: 87 GTA
If you think that the fan turning on 5 degrees sooner can save your engine.... Gonna take a lot more than a fan switch & 5 degrees to do ANY difference.
Old Jul 30, 2008 | 05:29 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
The jet fan switch part # is 60600
Old Jul 31, 2008 | 01:06 AM
Car: 1989 GTA
I agree. You gotta remember, once it hits 200°, that fan won't shut off until it's at 185° (which in AZ means it'll be on until November)
If you have A/C (and I assume everybody in AZ does), your fan should be on anyways. But the fan switch is nice for those days when you turn your A/C off and still want the car to cool down fast.
The $50 for the fan switch is money well spent. And it only takes about 3 minutes to install (when the car is on a lift)
Old Jan 1, 2009 | 10:44 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Is there any real differance between the Jet and Hypertech switches? Or is the extra $7 on the Hypertech piece just for the name?
Old Jan 2, 2009 | 07:06 AM
Tims91RS's Avatar
They both function the same. But the connectors are different. The Jet switch comes with a connector to splice on to your factory wiring. The hypertech uses the factory type connector.
Old Jan 4, 2009 | 12:12 AM
So basically the Hypertech is a plug-n-play whereas the Jet requires splicing wires for it to work properly. Is that correct?
1992 Trans Am
May 10, 2023 07:19 PM
twest2k2
Aug 24, 2015 11:26 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
