LS1 Fans Rad Mount Modifications
Old Jul 28, 2008 | 12:42 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Does anyone have any pictures or even a good description of what they needed to cut to get their upper radiator mount (third gen) to fit the LS1 fans? I've been cutting, test fitting, cutting, test fitting, and I don't think mine will ever fit right. If I could get a picture, or something, even a photoshop, it'd be immensely helpful. The car has been down for a few days for a serpentine swap, and I need to move out in four days from this complex. Doing it without a running car is gonna be very hard.
And no, much to my current dismay, I did a Cortez, and burned my ships to commit myself. I broke off the bolts from the lower fan mounts because I couldn't undo them with the wonderbar and the sway bar in the way. Whoops.
Any help on this is much appreciated!
Old Jul 28, 2008 | 01:54 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Re: LS1 Fans Rad Mount Modifications
I had a '02 LS1 fan setup from my parts car and looked at them compared with the dual TPI fans, and decided after a day to go with the TPI fans. You'd have to do a large amount of modification/shroud work to get the LS1 fans to mount right.
Old Aug 8, 2008 | 09:47 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i have lt fans not ls's so i'm not going to be of much help.
Old Aug 8, 2008 | 09:58 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
If you haven't done too much modification/cutting to the LS1 fans, you can sell them off and get a fan for a Ford Taurus. I'm not sure how hard it is to get the LS1 fans in, so if it will require extensive modification you can do this. These things flow ridiculously high. It has been keeping my Iroc at 180* at idle/cruise/wot, everything. Pretty cheap on ebay too and they will mount in with a very small amount of cutting to the fan and one screw.
Search for threads for it, it is a very popular cooling mod.
Old Aug 10, 2008 | 11:51 PM
Axle/Gears: 3.27 BW
You just have to cut it a lot. A lot. To the point it looks waaay too thin. But after all of the cutting, it holds nice and tight. Looks clean and factory too. That, and I don't like putting Ford parts in my car. :P
Either way, they push a LOT of air. Now I just need to swap my thermostat.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
