Oil in my coolant tank?
Old Aug 7, 2008 | 11:56 AM
l2oss's Avatar
Hey I my 1988 camaro seems to be leaking oil into the coolant overflow tank. I have no idea what could cause this. The only thing i could think of which would be terrible was if there was a crack in the engine block. I drained most the fluid out 2 weeks ago and filled most of it up fresh. Then yesterday it has oil in it again. The far runs fine and don't know how serious this is.
Any solutions or explanations?
Old Aug 7, 2008 | 12:07 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Re: Oil in my coolant tank?
Oil pressure is > than coolant pressure. So, if you had a head gasket leak between an oil passageway and a coolant one, the oil would flow into the coolant. You will likely get a reverse effect when the engine is turned off. So I would check your oil for a chocolate milk effect.
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
Is there coolant in the oil pan? Could possibly be warped cylinder heads or a cracked block as you said or bad head gaskets. I'm not sure if warped heads or a bad head gasket would lead to oil in the coolant. I had coolant in the oil pan way back in 89 or 90. The car didn't even have 20K miles on it. Turns out I had warped cylinder heads. Just another possibility.
Gene
Old Aug 7, 2008 | 12:30 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Oil+Coolant=Nothing easy to fix. I would guess a cylinder head problem, particularly head gasket, though I've been hearing about TBI heads cracking an awful lot lately.
Old Aug 7, 2008 | 03:06 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Had the same thing happen in mine. Cracked head. Sorry to tell you that, but it is most likely a cracked/warped head or a gasket problem.
Old Aug 7, 2008 | 03:51 PM
l2oss's Avatar
How much would you guys estimate that would cost to repair if it was a crack in the cylinder head?
And what kind of damage could happen in the future if i don't do anything to fix this problem anytime soon?
Old Aug 7, 2008 | 05:19 PM
safemode's Avatar
Car: camaro rs
if the reverse is happening (coolant in the oil, which is likely) then you might as well look out for a new engine. It's probably cheaper.
Old Aug 7, 2008 | 05:42 PM
jim91gta's Avatar
Car: 1991 GTA
Engine: 5.7
Radiator? Oil cooler leaking into radiator?
Old Aug 7, 2008 | 08:09 PM
l2oss's Avatar
No, there's no coolant in the regular oil, there is just oil mixed with the coolant overflow tank.
Old Aug 7, 2008 | 11:55 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
could be semi-cheap, such as a head gasket, or could get really expensive, such as warped or cracked cyl. head. one of those 3.
Old Aug 8, 2008 | 03:33 AM
l2oss's Avatar
Thank you everyone for your replys.
I will look more into it with what you all said.
Old Aug 8, 2008 | 07:39 AM
gcgarner's Avatar
Are you 100% positive that it's oil? Or could it just be brown coolant from an old nasty radiator? Might want to have your coolant system flushed a couple of times to see if the problem keeps recurring before you go diving into the heads. Is your oil level dropping?
Old Aug 8, 2008 | 08:04 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Sometimes corrosion makes that funky sediment that looks kinda like swirly oil, especially in the overflow tank. As for a cracked head, I agree with looking for a whole motor. I just picked up a 4 bolt main 350 out of a 92 suburban for 100 bucks off of craigslist. Find a deal like that and part the rest out you might even turn a profit.
Old Aug 9, 2008 | 01:48 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Could also be trans fluid mixing with the coolant. I have seen that lately. The trans cooler in the radiatior leaks. Check what your trans fluid looks like.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
