temperature switch not working?
Old Aug 23, 2008 | 01:55 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
i searched, but non of the threads seemed to pertain to my question.
i dont have anything stock, so the ECM doesn't control anything.
i was having overheating issues when i put together my new motor(stroked out 350 to 395, 10.8:1) i finally listened to my neighbor and bought VOLVO fan. the thing works awesome. it will bring the temp down from 245 to 185 in a matter of 5 mins while its idling in the garage!!!!
problem is the fan doesnt always turn on at the 185* mark. (that why it got to 245*.....)
i have a temp switch relay from summit
Summit SUM-890015
what could be the problem. the temp switch does not have any teflon on it
any suggestions........
Old Aug 23, 2008 | 08:11 AM
CamaroRider's Avatar
Re: temperature switch not working?
What temperature thermostat do you have installed ?
I read an article recently where the fellow suggested a 170 degree F thermostat (special order) and a temperature switch set at 185. He felt that combination was the best mix. I believe the temperature is being sensed in three places on your engine: The thermostat that allows the coolant flow, the heat sensor that feeds the meter and the temperature switch for the fan.
If you had a way to measure temperature at the temperature switch for the fan maybe you might find it IS switching at 185 degrees (at that spot on the engine). Just a guess.
Old Aug 23, 2008 | 12:26 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
thats what i was thinking at first, but then i realized it was @ 245 and still not turning on. i would a agree with with you if it was turing on @ say 195.
is there a way to check the relay. im gonna turn the car on in a few minutes see what it does
the thermostat is 180
Old Aug 27, 2008 | 09:50 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
ok, checked the relay, seems to be working fine.
i hooked up the temp switch terminal to a ground and the fan turns on no problem..... (with the key in the on position)
so the last thing ..... the temp switch???
i installed it in the back of the intake manifold (rpm air-gap)
you think it might not be getting coolant flow at this location
camarorider u might be right in a way.
maybe there isnt even coolant flow at the location of the temp switch and thats why the fan is not turning on.....
all connections seem to be fine
any ideas
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Reddeath210
Oct 6, 2015 08:20 AM
zeitghaist
Aug 18, 2015 07:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
