Please help 1986 iroc heater hose info needed
Old Sep 7, 2008 | 04:51 PM
jjegg's Avatar
I am currently installing a 1986 TPI engine in my 1965 Impala. I need some pictures and explanation of how the 2 heater hoses are connected to the motor. I have no hoses to try to install and need to buy something that will work. I have the heater core tubes coming from my firewall but need to know the best way to get this together. Thanks in advance. Pictures of the orginal 1986 setup would really help as we never seen the donor car the engine came from.
Old Sep 7, 2008 | 09:56 PM
1986Sleeper's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
Re: Please help 1986 iroc heater hose info needed
One Heater core hose comes off the firewall and goes to the nipple on the rear of the intake manifold.
The other hose comes off the firewall and will goto the port on the radiator, just under the filler neck.
Or you will have one port on your intake, and one on the water pump.
Hope this helps.
Old Sep 10, 2008 | 11:36 PM
87IROC92RS's Avatar
Car: 87 IROC
Transmission: built 700R4
Axle/Gears: 3:27 posi
on my 87 iroc the two lines come out form the heater core, one goes to the back of the block, then one on the side runs to the front of the block then a 3rd hose that trails down the framerail to a metal line
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
1992 Trans Am
May 10, 2023 07:19 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
