Only blows out defrost?
Old Sep 25, 2008 | 03:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
When the heat is on in my car, the air only comes from the defrost vents no matter what setting you have it on. What could cause this?
Old Sep 25, 2008 | 03:45 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
Re: Only blows out defrost?
Vacuum leak. The vents are conrolled by a vacuum swith behind the HVAC controls in the dash. You either have a leak in the lines or no vacuum coming to the switch.
Old Sep 25, 2008 | 03:47 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
You have lost vacuum to the HVAC controls. Either it was unplugged from the engine/control, or its broken somewhere. It comes out of the firewall about a foot down near the passenger head.
Old Sep 25, 2008 | 04:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The problem is common to our cars (defrost is the default), and as a consequence, a search will provide a wealth of info on the subject.
JamesC
Old Sep 25, 2008 | 08:52 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Can a leak at the switch cause any kind of problems with engine vaccum?
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
whibbs
Exterior Parts for Sale
Sep 28, 2015 07:53 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 3, 2015 09:26 AM
