Sensor next to coolant temp sens?
Old Sep 27, 2008 | 10:45 PM
jp sunshine's Avatar
Car: 87 TransAm
Engine: 5.7
Transmission: 700-R4
Axle/Gears: Stock
87 Trans Am 5.7. I got a code 15 so I swapped out the coolant temp sensor...code returned after clearing memory. I am going to do some re-wiring next. Less than an inch next to the coolant temp sensor is another sensor with two wires coming out also...the connector is damaged so I don't think it's operable...whatever it is. My Haynes manual has no mention of this sensor and I've searched all over this forum with no luck. Anyone know what it is so I can replace it?
Old Oct 4, 2008 | 12:49 PM
Todd Chastain's Avatar
Car: 87 iroc z28
Engine: 5.7 TPI
Re: Sensor next to coolant temp sens?
you have a pic.
Old Oct 8, 2008 | 08:31 PM
Car: 87 TransAm
Engine: 5.7
Axle/Gears: Stock
Here are three shots getting progressively closer.
Attached Thumbnails Sensor next to coolant temp sens?-10october-061.jpg   Sensor next to coolant temp sens?-10october-071.jpg   Sensor next to coolant temp sens?-10october-072.jpg
Old Oct 9, 2008 | 06:56 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I believe it's the cold start injector sensor. I notice you also don't have a MAF.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
