overheating question
Old Oct 4, 2008 | 12:31 PM
Todd Chastain's Avatar
Car: 87 iroc z28
Engine: 5.7 TPI
I'm not sure of the proper term, is there such a thing as vapor lock? If so how do you know if your cooloing system is having this problem and how do you fix it? I just replaced my thermostat and put in a new fan switch. Prior to doing this I suspected that my car might be overheating due to vapor lock, but again I am not positive that was the case. Is there such a problem, or am I just being paranoid?
Old Oct 4, 2008 | 07:24 PM
WS685ta's Avatar
Re: overheating question
Vapor lock happens when the fuel is heated up to the point to where it is no longer in liquid form. I dought you are having this problem with a fuel injector car because the fuel is circulating back to the tank.
Old Oct 5, 2008 | 06:08 AM
kcb37's Avatar
X2.
Vapor lock is more common on carbs too.
Anyway, you may just have air in the system.
Have you done anything to it lately?
Does it overheat sitting, driving at low speed, driving at highspeed?
Got to be a little more specific.
You can't tell us to much.
Old Oct 5, 2008 | 09:59 AM
Car: 87 iroc z28
Engine: 5.7 TPI
It would get hot while stopped at a light or driving thru town. On the highway it would do ok. At that time I hadn't done anything to the cooling system. The fans where working fine in the beginning but I believe they stopped for some unknown reason. In an effort to try to help/solve the problem I just 3 days ago replaced the thermostat with a 180 degree and replaced the fan switch with a new hypertech fan switch. I can perform minor mechanical repairs but I am by no means an electrician and I feel that my problem is electrical.
mustangman65_79
Sep 1, 2015 03:51 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
