JET Fan Switch
Old Oct 25, 2008 | 07:38 PM
87TPI305's Avatar
JET Fan Switch
I just installed a Jet stage two chip in my 87 Trans am 305 TPI and the fan switch thats also from jet that summit recommened. I ran the car with only the chip in the computer, then after installed the fan swith to were it told me and my temp gauge is past the red mark when its not even that hot. Did i do something wrong or is there a way this can be fixed quickly? thanks.....
Old Oct 29, 2008 | 09:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: JET Fan Switch
the fan switch is on the passengerside of the block, did you swap the jet one in place of the sensor on the driverside?
Old Oct 29, 2008 | 10:43 PM
87TPI305's Avatar
Re: JET Fan Switch
Thats where i installed it on the driverside of the car. The instructions said that it would be located between spark plugs one and three. I guess i messed up and put it on the driverside. Where exactly is the fan switch located at?
Old Dec 16, 2008 | 02:05 AM
donaldw's Avatar
Car: 1988 pontiac trans am
Engine: 305 tpi
Axle/Gears: factory
Re: JET Fan Switch
look on the passenger side of the block in between the very back spark plug and the second to back plug..you might only be able to get to it underneath..thats how i did it
Old Dec 16, 2008 | 11:06 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: JET Fan Switch
As previously states. Only on the passenger side, down just under the last two spark plugs but above the knock sensor which is more forward.
The sensor on the drivers side is for your temperature gauge.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
