Recommend a good radiator or a fix?
Old Nov 26, 2008 | 05:28 PM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
Hi there, I have an 89 pontiac firebird with the 350 engine tpi. Found out today that at the top corner of the radiator (where the hose hooks in) that I have a small crack/hairpin like crack in the radiator and spewing h2o. Since it is at the top, would any Stop Leak (Bars?) fix it or if not, what radiator do you all recommend? Autozone has one for 102 bucks with limited lifetime warranty. Any suggestions/ help would be greatly appreciated.
Old Nov 27, 2008 | 09:57 AM
kcb37's Avatar
Re: Recommend a good radiator or a fix?
If your not adding any power, then a stock type radiator is fine.
I don't like to use any stop leak, as it can clog up the radiator, and heater core.
If you have the money get a new radiator.
Old Nov 27, 2008 | 11:03 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The stock type replacement will be fine.
Old Nov 27, 2008 | 11:36 AM
rsrookie's Avatar
Car: 1992 Camaro RS t-top
Engine: 305 Jasper
TRUE DAT!! The radiator in my '92 RS was leaking at exactly the same spot yours was and I opted to get a new one.Ordered a stock replacement unit from RockAuto for $103.23, freight included.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
TreDeClaw
Aug 14, 2015 06:58 PM
