Anyone Make Their Own Air Dam?
Old Dec 2, 2008 | 09:47 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Mines kinda beat up and was looking at replacememts, but for $35 dollars i could easily make one "i think" lol. So any pics of custom ones?
Old Dec 3, 2008 | 12:07 AM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Re: Anyone Make Their Own Air Dam?
you might try going to a dirt trak supply place & getting the sheet plastic they use. I riviting it on. It worked for a capri I had. The stuff is fairly cheap too.
Old Dec 3, 2008 | 07:25 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
No junkyards in your area and nothing for sale on TGO? Should be pretty cheap to pick up a used one.
Old Dec 3, 2008 | 10:02 AM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
i was thinking about doing this because the stock ones always seem to curl under the car as opposed to scoop the air. not sure how much that affects its use though.
Old Dec 3, 2008 | 12:16 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I made mine out of 1/8 abs plastic and I fabed up some brackets and bolted it into the stock location. I made it hang a little lower and I put a little more pitch on it for more of a scoop effect. I have hit curbs and dips and all kinds of things and it has yet to move it much or damage it not even the oppossum I hit the other night damaged it.
Old Dec 3, 2008 | 12:25 PM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Got any pictures of yours? I was considering doing the same thing with sheet metal.
Old Dec 3, 2008 | 02:31 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Something hinged and spring loaded would be nice, so it could scrape/bump stuff and spring back without breaking. Although I can't imagine a way to do it that wouldn't look horrible.
Old Dec 3, 2008 | 05:34 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Great idea Ward! If you could do that it would end all of our air dam problems. Also ive looked at our local yard and they're all shot/missing. The ABS plastic and steel mount idea sounds good, anyone got a pic of theres?
Old Dec 3, 2008 | 06:27 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Although I haven't done it yet I was going to go to a sheet metal place and get them to a curve a piece of 18 gauge sheet metal then screw it in place somehow. What do you guys think of that idea? It should be cheap.
Old Dec 3, 2008 | 11:28 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
Mine rolled back and the supporting bolts were broke off. I made a new one and put it over the old and bolted them together with 1/4 inch bolts. I went to the junk yard with some wrenches and a hacksaw and found a Chevy S10 pickup with the rubber air dam on the front bumper. I used the saw to cut the length I needed, and the bolts are on the outside so it's easy to remove. It also has small braces on the backside that are molded in. Cost, about $2 since I had the bolts on hand.
Old Dec 3, 2008 | 11:42 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I will grab pics tommorow I was just adding some support to add some more angle to it. And its a air dam if it works it works and it don't matter if its ugly. Though with my design I could swap the brakets with small barn door hinges and two strong carb return springs. I have just finished my cooling system upgrade and the air dam, ls1 radiator, stock cooling fan with fan shroud, and performance 180 stat with vent hole is keeping the car REAL COOL.
Old Jul 1, 2009 | 12:06 AM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
I made a few air dams out of 18 gauge sheet metal. Screwed them on with 1/4 hex head self tappers. Works freaking great!!!!!!! Paints up nice too.
Old Jul 1, 2009 | 12:20 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
i made this thread many moons ago lol jk. I made one out of some polished aluminum, sorks great.
Old Jul 5, 2009 | 01:33 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Good idea putting more pitch on air dam. I would like to bring mine up an inch, and do the same thing. I can't go anywhere w/o dragging the dang thing somewhere. I keep my fans running constantly in the summer probably because the stock air dam isn't doing a great job.
Old Jul 6, 2009 | 02:32 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Could you post a pic of the air dam you fabbed? My camaro doesn't even have one I have a few sheets of stainless steel and aluminum lying around, and a bender. I think I'll make one myself if it doesn't look "too" difficult. Thanks
Old Jul 6, 2009 | 03:37 PM
I think abs would be a better choice than stainless or aluminum. I hit the road quite often with my factory dam. That's why they made them out of plastic, so they flex.
Old Jul 6, 2009 | 05:19 PM
Hmmm, thats a valid point. It would have to be pretty heavy duty if I made it out of metal so that it would hold it's shape.
Old Jul 6, 2009 | 05:55 PM
The metal air dam might be heavy duty, but where it attaches may take a beating. I'd stick to plastic. either shape one from another type of vehicle, or get a third gen one. Thats mho
Old Jul 6, 2009 | 06:16 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
If it's too strong it would damage your lower rad brace.
Here's Mine (there's still body shop dust over everything)
Old Jul 6, 2009 | 06:28 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
don't bump your head on that when you change your oil, you might decapitate yourself! lol
Nice job! I like the shape. not to strong for the radiator bracing? What gauge is the steel?
Old Jul 6, 2009 | 06:33 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
LOL i already cut my head on it when i was putting the bumper cover on.
It's really thin i'd say 1/8" total, it has a fiber type backing on it. If i hit anything i'm pretty sure it (airdam) would bend/pull out of the two bolts hoding it on. It really forces the air up though!
Thanks for nice words guys.
Old Jul 6, 2009 | 07:39 PM
Good idea to not have too much holding it on. That would be the answer if making out of steel. Anybody with a third gen knows those radiator/ engine compartments don't breath well. That's why I used a HO duel snorkle air cleaner with ducts instead of a chromie.
Old Jul 6, 2009 | 07:55 PM
Thats one way to go I guess...
Looks good by the way. I'm not sure if I want to do it out of aluminum or stainless steel though.
Old Jul 6, 2009 | 08:07 PM
If you made it out of metal, you would want it to "crumble" instead of destroying your radiator, or damaging fuel lines or brake lines. I Still say plastic is the optimum way to go. As I said before I bottom out on mine regularly.
Old Jul 6, 2009 | 08:15 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
I like the hinged and spring loaded idea... But, as it was mentioned, it might be difficult to make without looking like crap, especially with plastic. But, I have a few ideas, I doubt I'll have anything to show for it for quite a while though. There are other things on the car I should do first...
Old Jul 6, 2009 | 08:35 PM
Maybe you could make an angled one out of abs? I am getting interested in doing this. Having the dam completely vertical seems inefficient.
Old Jul 6, 2009 | 08:52 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
IDEA
take a stock one, cut it at the corner "L" (where it points down)
take and put a bevel on the edge of each side so it leans like the aluminum one posted above, use west systems g-flex epoxy
http://www.westsystem.com/ss/gflex/ trust me this stuff is stronger than the dang plastic you are bonding it and its made to flex to so it dont snap when you drag. i have used this g-flex before and its well worth every penny and its not to expensive to ball park of $20 depending on where you buy it, but DO get the G-Flex Epoxy Repair Kit, the kit make its easy as can be to work with
now i haven't done this to mine, mine seem to run cool just fine the way it is (im sure that all aluminum rad helps to ) but i feel that this idea would work, and BTW you can sand and paint g-flex
Old Jul 6, 2009 | 09:00 PM
BlueIroc-Z's Avatar
Yeah, vertical works, but like you say angled is much better. Only problem I see with it is if you do happen to scrape an angled dam while moving forward, there is the possibility that it will snag on/jam into the ground and just break... Perhaps a rolled lip on the front edge could minimize that issue. Although, that is more easily implemented on some kind of metal than plastic... You could always do a metal lip on a plastic dam...
Probably way more complicated than it needs to be, but hey if it works and works well, then who cares.
Old Jul 6, 2009 | 09:04 PM
I suppose jamming an angled air dam could be problematic. My concern is damage to the radiator frame. The air dam would be far easier to replace.
Old Jul 6, 2009 | 11:55 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
looks nice! can you come cut my grass? i have beer
Old Jul 7, 2009 | 12:59 AM
This is wrong! Your air dam is getting more attention than your paint job!
Old Jul 7, 2009 | 02:21 AM
Maybe plan on painting the darn thing!
Old Jul 7, 2009 | 04:46 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
I could cut grass with it i bet!
I should polish it up just for you guys, then we can have a long discussion about which polish is better lol.
Old Jul 8, 2009 | 02:26 PM
HairHag's Avatar
Car: '88 Camaro
Engine: 305 TBI
Going on the 'finding one in a salvage yard cheap' - i grabbed one from a gutted out '93 Buick Regal coupe that works great, so let me vouch for that one. Only needed to drill two holes to fit. And it fits better than one i grabbed from a Cavalier the same year as my Camaro. Best of all, they were both free due to multiple other purchases i made!
Old Jul 8, 2009 | 06:20 PM
I have a junkyard where I can find a ton of stuff like that.
Old Jul 14, 2009 | 01:17 AM
optima23's Avatar
does anyone have a picture of the stock airdam cause my underneath is all missing in the front and id like to see what it should be.
Old Jul 14, 2009 | 01:37 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
D@MN Imagine if you hit a cat!
Roadkill fillets everywhere!
Old Jul 14, 2009 | 03:01 AM
you don't want to push the radiator through your hood after bottoming out.
Old Oct 20, 2009 | 12:25 AM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
i made my out of sheet metal,i'll post some pic tomorrow
Old Oct 20, 2009 | 01:13 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
You know i was having a little bit of high temp on my water temp. Just looking at this I am pretty sure Mine is gone and didn't realize it made that much of a difference on cooling. I will be making mine to. and the hinge spring load is a nice idea just need more of a smaller angle b/c think if you hit a dip and you have a 45 degree angle it won't retract. Just a thought of theory.
Old Oct 20, 2009 | 06:07 AM
  #42
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Does anyone in here realize how the air dam helps the cooling system? It's not meant to "scoop" the air up in front of the radiator, It's designed to create a low pressure zone behind the radiator, essentially "sucking" the air through it.
Old Oct 20, 2009 | 06:52 AM
  #43
Twin_Turbo's Avatar
I don't think, it's designed to create a low pressure area because that would be very unefficient with air getting in from the sides, the wheel wells and openings next to the battery and the other side. its' designed to force air up through the radiator. If you want a low pressure area to suck air through the radiator, build an extractor hood...that's how they work, fast flowing air, detaching from the boundary layer by the big gaping hole and creating a low pressure zone, pulling air through the rad.
What that flap does is create a high pressure area so that air coming in from the front does not leak down under the radiator and reduces flow through the radiator
Old Oct 20, 2009 | 08:03 AM
  #44
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
here is one i made,
https://www.thirdgen.org/forums/fabr...t-air-dam.html
Old Oct 20, 2009 | 07:46 PM
  #45
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
here's mine just finished it today,waiting for paint to dry.I will install it tomorrow
Attached Thumbnails Anyone Make Their Own Air Dam?-000_0181.jpg   Anyone Make Their Own Air Dam?-000_0182.jpg
Old Oct 20, 2009 | 08:37 PM
  #46
What did you make it with?
Old Oct 20, 2009 | 10:23 PM
  #47
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
i used 1/16" galvanized metal
Old Oct 21, 2009 | 03:43 PM
  #48
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
here you are boyz.I installed my air dam and it looks sweet
Attached Thumbnails Anyone Make Their Own Air Dam?-000_0183.jpg   Anyone Make Their Own Air Dam?-000_0184.jpg
Old Oct 21, 2009 | 06:34 PM
  #49
Looks like a bang up job! The only thing I am thinking, is when you bottom out on the air dam, how will it affect your car. I frequently hit my air dam when I go into a driveway, or drive over a speed bump. The plastic factory dam flexes, and springs back.
Old Oct 21, 2009 | 07:12 PM
  #50
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
when you bottom out with a metal one, the dam will bend/crumple and not bend back. Neither of the two shown here would be sturdy enough that they would damage the car if they were hit.
