What's the best solution for this?
Old Dec 6, 2008 | 09:48 PM
bigbird89's Avatar
Car: 86 Firebird
It looks like rats have literally chewed the wires to my fan relay. There was a rat's net in front of the distributor when I got the car, so that's probably what it is. Do I need to splice every wire in the wiring harness, or is there a beter/easier way? On a side note, the ECM has been removed, but that shouldn't affect the operation of the electric fan, right?
Thanks for the help!
Old Dec 7, 2008 | 10:09 AM
kcb37's Avatar
Re: What's the best solution for this?
I take it your car was converted from a TBI or TPI to a carb?
The easiest is going to be to splice them back together.
I know if you have dual fans, the secondary does come on with the ac, not sure if it's controled by the computer or not though.
I almost want to say it is.
Old Dec 7, 2008 | 11:33 AM
bigbird89's Avatar
Car: 86 Firebird
I guess I should have mentioned that I have an 86 LG4, which was a ccquadrajet converted to a non cc carb. (I only converted because all of the emissions/electronics were hacked up by the previous owner)
I have a single fan, and I'm just looking for the simplest solution to getting the fan functional. Thanks for your input!
Old Dec 12, 2008 | 11:19 PM
bigbird89's Avatar
Car: 86 Firebird
So if I splice all of these wires, the fan will theoretically work correctly? Is there any other switch, relay etc. that I should check?
armybyrd
Sep 28, 2023 12:16 AM
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Giocio
Oct 1, 2015 12:20 PM
