coolant leak
Old Dec 18, 2008 | 12:26 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
coolant leak
so i have this leak. but im smelling antifreeze in the exhaust but not showing any bubbles in the radiator. none in the oil. im confused. pls help.
Old Dec 18, 2008 | 01:39 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: coolant leak
head gasket?
Old Dec 18, 2008 | 11:34 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: coolant leak
im thinking maybe lim leaking. it starts right up and idles perfect. to cold to do any work . unless i get it in my brothers shop to tear it down.. must be a very small leak. guess i will de ice the car and check it out tomarrow. since its a snow ice mixture atm.
Old Dec 18, 2008 | 11:41 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: coolant leak
how do you know its the exhaust? there are times that the t-valve where the coolant goes to the heater, it will crack from the heat and leak a small amount of coolant under pressure.
anyway, its easire to look at that than to pull the engine apart to see if you have a bad head gasket.
Old Dec 19, 2008 | 06:57 AM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
Re: coolant leak
ill check the valve thats a good possiblity. it leaked when i first started it up after changing the engine. tightened the clam. could be over tightened and cracked it.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
