Fans on Toggle not working?
Old Jan 15, 2009 | 03:56 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just wired up my fans to my new relays and toggle switch but they are not working. The fans are not getting power to them. Can anybody think of anything I might have messed up such as putting the wires onto the relays in the wrong spots, or anything that I should check out? Here is the diagram that I used.
https://www.thirdgen.org/forums/atta...hmentid=167187
Old Jan 15, 2009 | 04:36 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Re: Fans on Toggle not working?
That will work even tho the symbol for the relays is wrong.
Does you relay(s) click / energize?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jan 15, 2009 | 08:32 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I dont remember hearing them click. Only one wire on each relay has power to it and its the one thats coming from the battery.
Old Jan 16, 2009 | 07:29 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
OK I think that my wiring may be wrong. So according to the numbers on the website listed below should 86 be a 12v source, 87 a 12v source, 30 to the fan, and 85 to the toggle switch? If that is not right can someone please post up which wires go to which numbers? Thanks
http://www.eurekaboy.com/f250/relay101.htm
Old Jan 16, 2009 | 01:03 PM
NINÅ's Avatar
Transmission: 765R4
From your original post you indicate you’re using diagram 167187.
You didn’t say if the fan comes on by itself when the car gets too hot, of if when use AC.
If it does, with the car off, but the key in RUN, use a meter to find out which side of the coil goes where.
You will find one side of the relay coil going to 12 volts.
It’s the other side you need the manual fan switch to connect, and the other side of the switch to go to ground.
Happy Racing!
Old Jan 16, 2009 | 06:45 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The fans dont have any of the factory wiring since my car didn't come with dual fans. I just have the pigtails plugged into the fan and the rest of the wiring was made by me.
Old Jan 16, 2009 | 08:43 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yes, the relays are clicking when I put power to #87 on the relay. What could still be wrong causing them to not turn on?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
