Radiator Problem?
Old Jan 16, 2009 | 05:26 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Radiator Problem?
I have a 91 Camaro RS, with a 305 TBI. My question, when ever it is a bit hot out, the tempreture slowly creeps up. I removed the thermostat, but then it wouldnt warm up very fast so I replaced the thermostat with a 160 degree hi-flow. Helped a little, but it still happens. On mild days, its pretty good about staying cool. And I flushed the system twice.
Any advice would be awesome.
Old Jan 16, 2009 | 08:07 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Radiator Problem?
Do you have the air deflector on, and is there a ton of leaves and junk between the radiator and a/c condensor?
Old Jan 16, 2009 | 08:13 PM
Beltfed's Avatar
Car: '86 Trans Am
If you leave the cap off and let it warm up, eventually can you see the coolant flowing? Can you see any growth inside of the radiator?
Old Jan 16, 2009 | 08:30 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
I have a few leaves, but not in the way of any air flow. My air deflecters on, i brush it all the time. lol.
And the radiator flows, and as far as i know the fan works. when i kick the heat on it will usually bring it down, but it gets old having the heat on in the summer.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
utfan01ss
Sep 28, 2015 12:17 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Clean87TA
Sep 4, 2015 11:23 PM
