Coolant leak
Old Jan 19, 2009 | 01:00 PM
1988WS6's Avatar
Car: 1988 TA
Engine: 355 sbc
Coolant leak
I can see it dripping off of a pipe that runs under the radiator. Supposedly the radiator is new, so I would hope that isn't the issue. Assuming I get the pipe plugged, what other leak issues should I look for? The coolant level is always low when I check it.
Old Jan 22, 2009 | 08:25 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Re: Coolant leak
gravity messes with you on this one. jack the car up and let it run to see exactly where its coming from. could be a crack in the hose or a crack in the radiator.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
