car not getting to normal temp
Old Feb 3, 2009 | 11:42 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
So it very cold here in chicago. My temp gauge is very low not anywhere near 220 maybe in the low 100s when i put the heat on it blows room temp. But if the weather is 40 degrees or higher its right on normal temp.
Old Feb 4, 2009 | 09:17 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Install a new thermostat and report.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the day time!
Old Feb 4, 2009 | 09:20 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
Re: car not getting to normal temp
well you dont have to worry about it over heating
Old Feb 4, 2009 | 11:51 AM
50bmgshooter's Avatar
stat has probably failed in the open position as said above replace it and report back
Old Feb 4, 2009 | 12:53 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
My brother has NO THERMOSTAT and runs a consistent 160, Thats stock radiator, water pump, 50/50 coolant and racing it around every chance he gets.
My buddy also had this problem, he replaced his stat and bing bang boom he was good to go, now it gets up to the 190 mark, but never above 200 as I have seen so far.
Old Feb 4, 2009 | 03:46 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
i was having a simmilar problem replaced my stat. with the low temps the hot coolant transfers heat faster. driving down the interstate its very noticable. i wish i would of pulled the air dam off or placed some thing in front of the radiator partialy restricting it. most semi drivers in the winter have some form of wind break for the radiator.
Old Feb 4, 2009 | 05:04 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Originally Posted by enswrob
i placed some thing in front of the radiator partialy restricting it. most semi drivers in the winter have some form of wind break for the radiator.
Exactly what I did.
I spent all kinds of time last summer to make sure it didn't get hot. Then about 10 minutes on the interstate in January and the temp was around 130*F . In town it was just fine even with the heat blowin full blast so I just cut a piece of cardboard to cover up about 2/3 of the radiator. Makes it easy to pull it out for in town, and now I have heat on the highway.
Max,
Old Feb 4, 2009 | 09:20 PM
ClickClickVroom's Avatar
Car: 92 Z03 RS TBI
Engine: 5.0 L03
Lol if it's not hot enough for heat you clearly aren't driving fast enough :P
(Which is a paradox because higher speeds mean more engine work which means more heat, but more airflow over radiator which creates cooler temps).
Old Feb 4, 2009 | 10:20 PM
Car: 91 formula
I know it the stat. I really don't feel like pulling the throttle body off my tpi to get to the stat because its damn cold out. I do notice if I sit with my car idleing the temp will rise some and warm air will come threw the heat vents but when im on the move down goes the temp..
TheExaminer
Aug 26, 2015 04:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
