Replacement Fans
Old Feb 5, 2009 | 05:35 AM
Bungle's Avatar
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Replacement Fans
Hi All,
I have a 91 Z28 with dual fans. The left fan is loose and touches the radiator when running. This is a bad thing.
I also think the fan motor is done as it screams when it runs.
Can anyone recommend a source for a replacement? Or recommend a good aftermarket replacement for the dual fan setup that would give more cooling and still run the a/c?
Cheers
Bungle
Old Feb 5, 2009 | 07:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Replacement Fans
Originally Posted by Bungle
I have a 91 Z28 with dual fans. The left fan is loose and touches the radiator when running. This is a bad thing. I also think the fan motor is done as it screams when it runs. Can anyone recommend a source for a replacement?
You should be able to pick one up in any auto parts store. IIRC, I purchased at CarQuest.
JamesC
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
