dual fans
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
dual fans
I know you have one that comes on with temp.....
the other comes on with the A/C
is there reason why you wouldn't want them to come at the same time,
since they'll both be on with a/c anyway.....
I was thinking why only use half of the radiator for cooling
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: dual fans
The 2nd fan will come on if the coolant temp rises above
a certain temperature,not sure of the temp the 2nd fan
comes on at-240 degees i think.If i had a 3rd gen with
dual electric fans i would modify the wiring so both fans
would come on at the same time,triggered by a
thermostat about 10-15*above the coolant thermostat
opening temp as well as the A/C relay. With 2 fans,
A/C blower and A/C clutch all coming on at the same
could cause the ignition to cut out for an instant-if this
happens might have to modify some of the wiring.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: dual fans
If you haven't, you might check Willie's sticky.
JamesC
JamesC
