fan turns on manually but not normally
Old Feb 28, 2009 | 07:49 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
my 1990 RS 305 has always had a radiator fan problem, until i replaced the fan motor, after I did this it still wouldn't turn on by itself but it would turn on if i turned the a/c or fan on, so I am left constantly running the ac, what's the problem here? what needs to be replaced to get it to turn on at it's original programmed temperature?
Old Feb 28, 2009 | 10:09 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: fan turns on manually but not normally
I believe the temperature it needs to reach for it to turn on is 236* I'm not sure how I came up with that but I seem to remember it from another post. There are several stickies that show you how to diagnose your system.
Old Mar 3, 2009 | 07:50 PM
92RSZ03's Avatar
Car: 92 Heritage Camaro
Transmission: 700 R4
I had this too on my manual fan switch, problem was the ground came off on the switch side so the AC still worked. If your AC turns on the fan you have a bad sensor, connector or burnt (close to exhaust) signal wire side of your circuit.
Old Mar 9, 2009 | 09:25 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
The AC always turns on the fan when the car is running properly, but if the sensor that taps into your passenger side head with the green wire attached to it goes bad then you either need to replace that sensor, hardwire your fan, or always run your AC.
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
