Squeeling when heat is on?
Old Mar 1, 2009 | 08:13 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Everytime I turn my heat on. the hear a squeeling sound coming from the vents. How do I get to the fan to check it out?
Old Mar 2, 2009 | 07:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Squeeling when heat is on?
There's pic of the fan housing in the following pic:
https://www.thirdgen.org/forums/elec...aro-rs-no.html
Remove the necessary wiring and bolts and pull the fan and cage out. I'd suggest stuffing a towel/rag under the housing to catch the screws which you will undoubted drop (Don't ask me how I know!).
JamesC
Old Mar 2, 2009 | 03:50 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
before you do that you should probably check your alternator and belt
Old Mar 2, 2009 | 05:51 PM
JamesC's Avatar
How would the alt/belt impact noise from switching on the heat?
JamesC
Old Mar 2, 2009 | 06:44 PM
Brennan's Avatar
he said it squeals when he turns on the heat. the blower motor draws a nice bit of power so the extra drain on the alternator could cause it to squeal if the belt was loose or bad
Old Mar 2, 2009 | 07:13 PM
kcallais's Avatar
Car: 1985 Z28
Nah, it was the blower motor. Pulled the cage off and it squeeled when I spun the shaft.
Old Mar 3, 2009 | 12:14 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Is true about the belt though-mine will do that with
a loose belt.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
