NEED HELP!
Old Mar 7, 2009 | 04:46 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
NEED HELP!
Today i tryed getting the ac running in my car, because i new it worked, it just leaks freon like crazy. Today i tryed getting 2 cans of stop leak and 2 cans of freon, and it the compressor was turning and everything and it started getting freezing inside the car, while all at the same time, it was just pooring leaking freon and stop leak like crazy. i have a picture and the gasket o ring set. But does anyone know how to get the bolt off. i tryed hard with 2 different wrenches but that thing is on there good.
Old Mar 18, 2009 | 09:27 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
SEIZE THE MOMENT
Frequently these are hopelessly seized.
It will be faster test all the nuts, find out which are seized, pick up replacement parts, cut the bad parts out, and bolt in new parts.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Mar 19, 2009 | 10:31 PM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
Re: NEED HELP!
Hold the welded end of the accumulator with a wrench, and turn the nut counter clockwise (the low pressure line nut). If your nut is seized, might be wise to buy new lines and an accumulator. Do it when the lines are warm, it might be easier. You might also try to persuade it by putting a pipe on the end of your wrench for more leverage.
Old Mar 20, 2009 | 12:44 AM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Re: NEED HELP!
And make sure your using the proper tools. You need a line wrench to avoid rounding it, not a regular wrench.
