swap q's
Old Mar 13, 2009 | 12:59 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
swap q's
my 305 TBI uses a block mounted switch to turn on the single fan, well im converting to TPI what do i need as far as cooling goes?
Old Mar 15, 2009 | 11:25 PM
Chevy8588's Avatar
Re: swap q's
bumb?
Old Mar 15, 2009 | 11:39 PM
jlanham's Avatar
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
Re: swap q's
I am not the most experienced guy on this board but I just got done taking this all apart. If it was me I would go get the double fan from a junk yard that connects to the tpi system. TPI cycles it on and off and the relay from what I can tell would not just plug in to a TBI single fan. I am having to do the reverse and have to get my tpi fans to work with a holley stealth ram wiring harness so thats what research I have put into it.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
