fan relay?
Old Mar 22, 2009 | 04:16 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
fan relay?
i got my camaro out from storage yesterday. and i took it on the highway and it was fine, but when i got in town it heated up to about 245 degrees.
and when i checked it, it looked like my fan was moving kindof slow.
heat was on high, and it didnt cool down much.
any suggestions?
Old Mar 23, 2009 | 07:23 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: fan relay?
any advice would be great!
Old Mar 23, 2009 | 07:37 AM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
Re: fan relay?
it could be the relay, switch, or fan itself.
when i had problems with the fan it was always the relay , but when my relay crapped out on mine it would completely not work.
your fan works so it could be the fan switch going bad.
but im not 100% so...
Old Mar 23, 2009 | 10:20 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: fan relay?
Sounds like the fan motor may be give out, IMO. Usually the relays will quit all together.
Old Mar 23, 2009 | 11:36 AM
AE Twitch's Avatar
Re: fan relay?
I just had this issue myself, it was my fan motor about to go out on me. I just bought new aftermarket fan assembly from Hadin performance. Works great now.
Old Mar 23, 2009 | 04:53 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: fan relay?
ok ill try the fan motor.
thanks alot guys =]
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
