Did it overheat?
Old Mar 28, 2009 | 08:56 PM
BlKnt18's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
Did it overheat?
Ok so I went out on a drive awhile ago and car was running good and temp was around 165ish. Got back on the interstate and gauge said 280..maxed out. I don't think this can be because the coolant was not boiling and engine was acting normal. Also, I checked my coolant and it is supposed to boil round little over 200 because I need to mix it better. I just put a new sending unit for the gauge the other day and it was working great. So maybe it is bad?? It is just a one wire gauge that has a spring in the unit...I know this because I broke the last one lol.
Old Mar 28, 2009 | 09:10 PM
BlKnt18's Avatar
Re: Did it overheat?
I'm pretty sure it is the gauge or sending unit. I went and let it cool down then started it up and it was around 120 or so then I rev'd the car up and the gauge shot up to max so idk what is making it do that. Maybe I need to solder the wire to the sending unit like it was before. The instructions said you could crimp it but that may be the problem.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
steimel94
Sep 23, 2015 12:48 AM
bryan623
Sep 19, 2015 10:13 AM
