Sealant For Cooling System Gaskets
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Would you use any sealant when installing a temperature sending unit or fan switch in the block and what type? I am sure these things must come with gaskets. I remember I used gasket sealant when I installed my water pump and thermostat.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Sealant For Cooling System Gaskets
they are threaded fittings, so you would use teflon tape or pipe dope.
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
