Radiator air dam
Old Apr 6, 2009 | 09:30 AM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
Radiator air dam
Does anyone know where I can get a "radiator lower air deflector?" it's for a 87 TA. I have the upper piece but not the lower, and my car has an overheating problem. The tech article said the part number is 10017673. I checked Jegs but that number wasn't found.
Old Apr 6, 2009 | 10:41 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Radiator air dam
Check www.ecklerscamaro.com or Hawks
Last edited by scooter500; Apr 6, 2009 at 10:41 AM. Reason: Forgot to add site sponsor
Old Apr 6, 2009 | 10:46 AM
Stephen's Avatar
Car: 87 GTA
Sounds like a GM part #, which Jeg's won't have (factory parts).
As for an aluminum one....Good luck having it not bend if it scrapes the road, bends back, stays bent, and being almost useless afterwards.
Old Apr 6, 2009 | 10:54 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
I want to say modern day muscle has the exact part, don't quote me though, it's been a while since i've looked.
If i'm not mistaken, this is what you're looking for:
http://www.moderndaymuscle.com/inc/sdetail/940
You would have to speak to them to be sure that it's for a T/A, as i believe they are different from birds to T/As. I had one from a T/A out of the yard and it didn't look like it would line up correctly on the bird pieces. I don't know so ask them.
Old Apr 16, 2009 | 10:42 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
i made an aluminum one for my iroc, the cars not on the road yet but i dont think it will drag unless i get careless, i traced the design of the old plastic one, then made the aluminum one about half an inch shorter and at more of an angle, i hope it doesnt drag, only took me about 20 minutes to make it and we have an abundance of scrap aluminum, my dad works at Alcoa so yea.
Old Apr 16, 2009 | 02:27 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Made mine out of abs plastic and made adjusters for it so I can make it work a little better and keep it from pulling off.
Old Apr 26, 2009 | 12:18 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
would you know where I could get a template for an airdam.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
edoff13
Sep 11, 2015 03:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
