Fan not working at all
Old Apr 8, 2009 | 11:04 AM
RTGTA's Avatar
Car: 2009 Silverado 1500
Engine: 5.3 Vortec
Hey everyone I have a slight issue on my hands. My fans don't come on at all. I just tried jumping the connector for the coolant temp sensor and they still didn't come on. I have narrowed it down to ECM, Fan relay, or wiring... the fans worked with a filthy wiring job, I unhooked the wiring and now the fans don't come on at all. The fellow who did the wiring just tied into the red/black wire from the relay to the fan and it worked fine. Any suggestions?
Old Apr 8, 2009 | 08:58 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Fan not working at all
ouch! bypass the insanity and get a $25 Zirgo fan control switch (180* - 240*), a new $6 30 amp relay, a $3 20 amp fuse holder w/ wires, $3 of black & $3 of red 16 gauge wire, some $3 14-16 connectors, & then use electric solder to connect it.
Old Apr 8, 2009 | 11:10 PM
RTGTA's Avatar
Engine: 5.3 Vortec
After work today I pised around with it and got it running like it should from the factory, except I found that the wires to the Heavy Duty Fan Switch are broken, so I'll have to fix that, but I also noticed whil eunder the T/A that I had a nice Coolant leak from up above... holy intake gasket... needed a new 305 anyways
Old Apr 12, 2009 | 02:47 AM
RTGTA's Avatar
Engine: 5.3 Vortec
Just an update: it's the waterpump that's leaking bad, the intake gasket is leaking but is not a huge worry, how hard is it to change the waterpump on a 305 TPI... looks like it won't be too bad. Also, wondering on the best fix for the Heavy Duty Fan Switch. The wires are broken right at the sensor, so if I order a new sensor does it come with a new pigtail or do I have to order a new connector? Thanks in advance!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
