upgrading engine
Old Apr 14, 2009 | 08:49 PM
redirocz28's Avatar
Car: 1986 z28
Engine: 350 from 305
Transmission: t5 borg werner
upgrading engine
I pulled out a 305 that had a 160 stat that normally ran well once the thermostat opened, but I am putting in my 350 this weekend,and will the 350 w/ a 160 stat w/ single fan be enough for it or should I start looking around?
Old Apr 19, 2009 | 01:41 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Re: upgrading engine
I have a 2 row, 1" tube, all aluminum radiator, "direct fit" brand new in box, has warranty through me for 12 months, $255.00, has a/t cooler, port for heater return hose if needed, port for low coolant indicator if needed. I have sold many of these, no problems. will have to modify fan mounts as radiator is 3" thick at the header plated (the area on the tanks where they are welded onto the core & sit in the rubber insulators ) & core is 2 1/4" but mods are minor. This is double the oem aluminum radiator. Have similar rad in my car w/383 & blower, no problems.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
