fan
Old Apr 20, 2009 | 10:48 PM
cody dunn's Avatar
Car: 1983 firebird
Transmission: t-5
Axle/Gears: 10 bolt, locker, disc brake setup.
fan
i have a single electric fan and it used to come on when the key was on but who ever owned it before me cobbed all the wiring and when i changed motors the fan wont come on anymore, so i was just wandering if i could run a wire stright from the fan to the fuse box, to a port that comes on when you turn the key on?
Old Apr 20, 2009 | 11:15 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: fan
Better to use a relay because the fan will pull about
20 or more amps as it's getting up to speed,10-12
amps at full speed,it's easy to rig up a reliable
thermostatic control for an electric fan-did it on an'89
v-6 firebird with FUBAR fan wiring,used a flex-a-lite
adjustable thermostat of the type that has a metal
sensing bulb with a capillary tube connecting to the
switch-took the upper radiator hose off,put the sensing
bulb into the hose,reinstalled the hose with the
capillary tube leading out(a dab of silicone under to
help seal)used this switch to control the fan relay
with the relay taking power from a fused feed off
the alternator output stud.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
