Mech fan shroud fitment
Car: 1986 firebird
Transmission: THM350
ok im converting over to a mech fan, theres a shroud im looking at thats from a 84 Z28.
Are the shrouds different between birds and camaros, or can I drop it in and call it a day?
(please don't come in here saying blah blah blah about electric fans)
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Mech fan shroud fitment
Fan shrouds are the same between Camaro and Firebird. If you have a factory power steering fluid cooler(pipe) you may have to tweak the metal lines near the steering box to clear the mechanical fan shrould.
Car: 1986 firebird
also hawks shows dif p/n for camaro and firebird shrouds, and they seem a bit different from the pictures.
you sure there interchangable?
Yup. Thats the fluid cooler. Its suppose to cool the fluid slightly before it goes back into the PS pump reservoir.
Car: 1986 firebird
Car: 1986 firebird
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
i used a mechanical shroud from an 84 camaro on my 84 firebird when i did the v6 > v8 thing it fits but does seem that the hood braces have put 2 grooves in it... didnt seem to interfere with closing it, or anywhere else
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I too am tired of the e-fan set up on my 84! I have it controlled by a on/off switch.
Gotta do the salvage yard search for a shroud/fan/extension set up and its good to know the bird/z shrouds are different!
This rust free NC Z is gonna be heading to my Daytona house for my Fla. winter car! I am sick of the yearly drive from NY to Fl !
I have my Goat for NY summer crusin'!
I want to make sure that somebody won't forget the switch and cook my motor!
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
The camaro shrouds use an 18.5"fan,firebird 17" fan
both are deep-pitch 7 blade clutch fans,the fan used
on the '82-'85 camaros is also found on '81 2nd gen
camaros,firebird 17"version is also found on some
cadillacs with the 368 or diesel engines,clutch hub
might be different on those.
