Temp Gauge Maxes Out
Old Apr 27, 2009 | 10:49 PM
scarron's Avatar
Engine: 82 Pontiac 305
Water temp gauge was working but after the first drive after getting it on the road I noticed that it stopped working. I popped the hood and notcied that the guy that had the car before me had threaded the wire around the power steering linkage and it had been yanking out and thrown against my headers and melted through and disconnected. I re-ran wire and when I turned on the car the needle buries itself at the 250 marked.
Anyone know what would cause this? Did it short out on the headers? Could this be fixable ot get a new gauge?
Old Apr 28, 2009 | 03:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Temp Gauge Maxes Out
the wire is still shorted somewhere.
Old May 4, 2009 | 11:56 PM
CamaromanCJ's Avatar
Car: 1986 Chevy Camaro Z28
Engine: LG4/OHV/4bbl/305/5.0
My 1986 Camaro Z28 does the slam to the max temp some times when turning the key. Oddly enough when I press on the key forcing it into the ignition it triggers back down all by itself. So might try that and see if that works, if that does. Not sure whats shorting cause I haven't gotten that far myself.
Old May 5, 2009 | 12:25 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
when I turned on my car the needle would sore too, replaced the sensors didn't help. then I replaced the gauge it self and now it works now. so im pretty sure it was the gauge that went bad.
Old May 7, 2009 | 11:41 PM
84HyperZ's Avatar
Car: 1984 Z28
Engine: 4bbl 305ci
Axle/Gears: 10 bolt 3.42 w/ Auburn LSD
i am having a similar issue. I was having a problem w/ the needle getting stuck when i turned the key. Replaced the sensor and now the gauge works but only reaches above the 100 degree mark just as the 190 degree thermostat is about to open. anyone have any suggestions on this?
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
