Please help!!!
Old Apr 30, 2009 | 07:57 PM
tibbitt23451's Avatar
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
Please help!!!
I have a lo3 91 rs . My fan will not come on, I have replaced the fan switch on the passenger head between 6 & 8 cylinder. I ran the can and the temp got up yo a little over 220 without the fan coming on. Before I put in the new fan switch I grounded out the wire to the block with the key on & the fan came on. My question is does the fan switch only work as a secondary way of cutting on the switch? Should the ecm cut on the switch at a certain temp? If I turn on my a/c the fan turns on. Could it be the ecm temp sensor in the front of the intake? I have a single electric fan.
Old Apr 30, 2009 | 08:55 PM
king1960's Avatar
Re: Please help!!!
On my 88 the fan switch and knock sensor are on the other side of engine
Old Apr 30, 2009 | 10:42 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Please help!!!
There are lots of threads on this. I believe the fan comes on when it gets hotter. These cars run hot.
Kevin
Old May 1, 2009 | 06:17 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Please help!!!
I finally installed a seperate temp probe, relay, fuse & keeps temp where I want it now
Old May 1, 2009 | 10:54 PM
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
Re: Please help!!!
I just did the same thing today, Probe fan switch set @185 & 170 thermostat, NO MORE PROBLEM
