what is wrong with my fan
Old May 2, 2009 | 01:06 AM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
my single fan 91 305 rs had an overheating issue due to a defective fan-motor; replaced it, after that was solved i encountered another issue, now the fan only turns on right before the overheating point in the last 1/4 of the temp guage. so the question is what is wrong, is it a malfunctioning sensor...........?
Old May 2, 2009 | 09:56 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: what is wrong with my fan
Your fan isn't supposed to turn on until about 230 degrees so that sounds about right.
Old May 2, 2009 | 10:17 AM
WestCoastCamaro's Avatar
Car: 1984 Z28
Yeah, I have the same problem, no fan until right before it gets to the red. Its really nervewrecking.
Old May 2, 2009 | 11:45 AM
shanewbenson's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: IROC 700R4
Yea mine did the same thing. just wire in a manual switch so you can turn them on whenever.
Old May 2, 2009 | 07:08 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Yea you can wire in a switch like shane said or hypertech makes a fan sensor that goes in the head to replace the stock one that comes on at 186 i believe.
Old May 2, 2009 | 07:22 PM
JMR's Avatar
JMR
green92 before the overheating incident the fan engaged @ 160 or at least the temp guage never marked anything over and now it turns on @240-250 aprox so would the problem be the switch?
Old May 2, 2009 | 07:25 PM
Dyerseve1988's Avatar
Car: 91 Camaro RS
Engine: 355 4BOLT
Axle/Gears: Stock 10Bolt
check the temp sensor i have a 91 rs and never had that problem at all the gauge always stayed normal and the fan came on
Old May 2, 2009 | 08:09 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Check your temp sending unit which is in the driver side head sounds like it may be causing you problems by the gauge showing 160 when the fan engaged and now it shows 240 before the fan comes on. Like thirdgen said the oe setting is around the 230-240 mark. So its possible that your car has always been hitting that oe mark before the fan came on but your gauge was showing 160.
Old May 2, 2009 | 08:35 PM
Antoneal's Avatar
Car: 1969 Camaro SS
Engine: 396 bbc Berger built
Transmission: 4 spd stick
Axle/Gears: 4.11 posi
What would cause a fan NOT to turn on period, not at 230, not at start... etc.
originally it would turn on AS SOON AS THE KEY WAS TURNED, not it doesnt turn on period, not one of the fuses under the consol are blown
Old May 2, 2009 | 10:03 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
If you still have ac in the car when it is turned on the fan automatically comes on. If it is not coming on it could be the fan motor, but it also sounds like your fan sending unit is bad.
Old May 2, 2009 | 10:47 PM
Former Sponsor
Car: Too many
If your fan used to come on as soon as the car was turned on that meant it has been rewired. Either the wiring is messed up somewhere or your fan motor is probably bad. It could be the relay but most people tend to bypass that when they wire the fan to run off the ignition. If you need a fan we have them available on our website but I would start by checking the wiring.
Old May 3, 2009 | 10:56 AM
Antoneal's Avatar
Car: 1969 Camaro SS
What is the tool that is required to check the relays? and where are the relays under the hood on the 91? (i thought they were where they were on my old 4th gen but i was wrong)
And would possibly taking a volt meter to the plug and seeing if the fan is getting power prove that the motor is bad?
Old May 3, 2009 | 02:46 PM
84 Z28 Bowtie's Avatar
Car: 84 Z
Engine: L69 305
Axle/Gears: 3.73 Posi
If the fuses are good, a bad fan relay, a bad fan or a bad temp sensor.
I believe the relays are prone to having a meltdown. I tried to replace mine with one from a junk yard and found that all 5 vehicles in the yard had the connector pack melted where it plugs into the relay.
Mine is located on drivers side firewall, closest to the fender.
Once you find the relay, pull the plug and check for voltage, if you have 12v+, jump power across it to see if the fan comes on. If it does, get a new relay. Their fairly cheap and easy to get (I think mine was $15)
Fanatic1074
Oct 3, 2022 05:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
z28joe2
Sep 28, 2015 05:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
