bypassed heater core and its still a puddle on the floor help plz
Car: 84 camaro berlinetta
Engine: 2.8 V6
Transmission: 700 r4
i have a 89 camro rs and my heater core just went out so its almost summer time in texas so i figure i dont need it so i bypassed it and yesterday there was i huge puddle on the floor wat da hell?!?!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: bypassed heater core and its still a puddle on the floor help plz
the core still has fluid in it, it will eventually stop leaking.
The puddle is antifreeze and not just water right?
Engine: 2.8 V6
i think its just water but because of the leak i put mostly water in the car
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Get an air hose and blow out the heater core. Then you probably wont have any more puddles.
Just thought you'd find this interesting. I also have an 89 RS and when my heater core went south, I was going to bypass the core like you did. As it turned out, I didn't have to. All I did was move the temp lever on the heater controls all the way over to cold and it bypassed it anyways! If you have an A/C car, the heater bypass valve automatically cuts off coolant flow to the core when you move the lever to cold. If you have a faulty bypass valve, or your car is non-A/C, then disregard this.
BTW, I only did that for the summer. Once it got towards the fall, I took the plunge and replaced the leaky core.
BTW, I only did that for the summer. Once it got towards the fall, I took the plunge and replaced the leaky core. Re: bypassed heater core and its still a puddle on the floor help plz
I think everyone dreads this,including myself. It's such a pain thing to fix. If anyone needs a new heater core here's a link to them on our site.
Camaro Heater Core
Camaro Heater Core
