Help !!!!! its overheating constant
Old May 6, 2009 | 01:26 AM
FatalTheRabbit's Avatar
Hi guys, Rabbit here.. Finally made a account because i ran into a problem and I have no idea what to do anymore.
I have a 1988 Trans am with a 350 swap/rebuild
Ive been having problems were she is overheating
to the point were the coolant will start to boil and back up and be pushed
out thru the overflow.. Currently I have
Replaced Every Hose for the cooling system
Put in a new waterpump
Flushed the entire cooling system
Put in a new thermostat
So everything cooling wise is brand spanking new!
However, No madder what she will overheat it will climb and climb until
the coolant boils, Im stumped
I fear I have a blown headgasket
thanks for the help in advance!
Old May 6, 2009 | 01:30 AM
tdavolos's Avatar
Car: 87 GTA
Re: Help !!!!! its overheating constant
Do you have the air skirt under your car ? make sure its there. Check your timing to.
Old May 6, 2009 | 08:04 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Hi guys, Rabbit here.. Finally made a account because i ran into a problem and I have no idea what to do anymore....
Pull the radiator cap when it's cold, start the car, and allow for the air trapped in the system to vent. Watch the coolant carefully, and you will see tiny air bubbles. Once the bubbles stop (give it a few minutes), the air will be out, then put your radiator cap back on. If it continues, try the procedure again just to be sure. If it doesn't work, grasp the upper radiator hose with your hand when the engine is warm, and see if it's hot. If it isn't, you have no coolant flow, thus it won't be cooled. By the way, is it a new radiator cap, and if it is (or isn't), what does the pressure on the cap read....
Old May 6, 2009 | 01:23 PM
oil pan 4's Avatar
Car: 89 Firebird
Make sure you have a good radiator cap that holds pressure.
You should have at least a 16lb cap.
If you use a high flow thermostat some coolant will always flow. That makes it easier to burp the cooling system.
To me it almost sounds like you have low coolant (air bubble) or a bad cap.
Old May 6, 2009 | 10:28 PM
I tried it 3 times but she still over heated.
It has coolant flow I can feel it going thru the lines
tdavolos- Yes I do , and the Timeing is set to 16 to run on premium fuel better
oil pan 4 - Cap is good and I the thermostat is a 160 Degree
So I am sure their is no air in the system.
Old May 7, 2009 | 01:31 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
ever check the radiator itself? flushing isnt a cure all unfortunately i had my system flushed and my fluid looked like crap after they filled it, its possible that its just shot. I just had to replace my radiator and the system runs like 15* cooler, internal blcokage is hard to find but it could be that
Also have you checked fan operation?
If youre worried about a blown head gasket; Check your oil and antifreeze make sure none of its mixing into that wonerful milkshake substance lol Just to knock out any fears in the back of your mind go get a compression tester and test all the cylinders, if you find 2 adjacent cylinders that have a close reading and theyre lower than the other 6 cylinders then you blew a gasket
Hopefully thats not the case
Old May 7, 2009 | 06:51 AM
I tried it 3 times but she still over heated. It has coolant flow I can feel it going thru the lines....
If your getting coolant flow, w/no trapped air, and your fan is working, and your running a fourteen to sixteen pound radiator cap that is functional, there is no reason why your coolant shouldn't be cooled. Except for.....;
Yes I do, and the Timeing is set to 16 to run on premium....
Please tell me that your not talking about your base timing here....
Old May 8, 2009 | 06:56 PM
Sorry the firebird is timed to 14 the 5.0gt is timed to 16, I gotta little confused while posting
Old May 8, 2009 | 07:57 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
When you had the cap off with the engine running did you notice bubbles continuing after the car warmed up? You are leaving it off until the thermostat opens?
14 degrees is a lot. When you set it did you have the flat 4-pin connector unhooked. Try backing down to half that.
I usually replace the radiator last. But that always seems to be the problem.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
