Radiator Fan Switch Relocation
Old May 17, 2009 | 03:14 PM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
I did a lot of searching but didn't find anything really covering what I want to do. I got my new 350 and there is a plug stuck threaded in the hole in the passengers side head where the radiator fan switch sensor goes. I have done all I can think of to get it out. It has a square hole like the plug in a differential, problem is that it is somewhere between 1/4" and 3/8" drive, so I can't put a ratchet in it to get it out. I have tried sticking square stock into it and turing it with a wrench and only ended up breaking the stock I was using. Its very stuck. I tried heating it up with a torch, but do not want to heat the head TOO much. So I was wondering if there would be any good places I could relocate this sensor to? I found a thread that touched on relocating it to the water pump but they decided it was on the cool side of the cooling system so it will not work. Anyone have any bright ideas? Thanks in advance!
Old May 17, 2009 | 04:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Radiator Fan Switch Relocation
somewhere on the manifold, under the t-stat would work fine.
Old May 17, 2009 | 04:53 PM
I don't see any good places to put it in there unless I put a T in where the coolant temp sensor is, you think that would work?
Old May 25, 2009 | 07:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The factory-style fan switches suck anyway - all of them suck, even the aftermarket expensive ones. I went through 4-5 of them, and got tired of fooling with it. Just ditch it. Replace with a seperate fan controller that has a probe that inserts between the radiator fins. I got a nice one, fully adjustable and allows one to rig in-cabin always on/off switches to it, as well as adjust the temp it comes on and goes off. It was a Flex-a-lite 31165, about $100 - and well worth every cent!
my86bird
Oct 23, 2015 12:20 PM
luvofjah
Sep 3, 2015 07:08 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
