what's wrong with my fans?
Old May 18, 2009 | 09:50 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
I have spal dual 11" electic fans, here is my problem. when I start the car and it is warming up, if I rev it a bit, the fans kick on and stay on until the car is warm/hot (running temp). once i shut the car off or they kick off, they work fine, except for the ocassional flicker on and off when I stomp on it? why is revving it causing them to kick on? too much voltage to teh relays? here is how i have them wired
Ignition________toggle switch__________relays (power) the toggle allows me to turn them off if they don't need to be.
battery ground_____________toggle___________relays (manual ground on/off)
2 power (one for each fan) _____________relays_______to fans.
I'm at a loss on what is giving them power, if they flip on and I but the power switch they shut off, so it's like they are getting ground from somewhere else? any ideas would be great, sorry for the crude schematic.
Fanatic1074
Oct 3, 2022 05:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
z28joe2
Sep 28, 2015 05:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
