help me fix my hacked up fan wiring... please!
Old May 30, 2009 | 10:23 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
i have an 87 iroc with a 305 tpi and the dual fan set up. when i first got the car the fan wiring was hacked so i just rigged it so the fans were always on when the key is on. i really want to put it back the way it is supposed to be so i need some guidance. ok... so.. both fans have two wires coming from them. they have all been cut right in front of the alternator (4 wires). i found a large flat plug next to the relay (which i have replaced) and it has two wires coming out of it that have been cut, a black wire and a black and red wire. there is also another black and red wire that goes off into the harness right there by the plug. also, on the both sides of the plug it looks like there were green wires that have been snipped off right at the plug so you could not add wire to it..
i realize this may be confusing.. but if someone has the same setup as me and could check where these wires go that would be great! ..and yes, i searched the forums and couldn't come up with anything.
Old May 31, 2009 | 07:50 PM
Re: help me fix my hacked up fan wiring... please!
anyone??i think that if i knew where the fan wires went i could figure the rest out..
Old Jun 1, 2009 | 12:04 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
if you are interested, i
Icould get you the wiring diagram for the1992 dual fan set up.
Old Jun 1, 2009 | 07:28 AM
i would say it's worth a shot.. thanks for the help!
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
WickedBowtie
Sep 11, 2015 11:24 PM
scotrans am
Sep 5, 2015 04:26 AM
