better cooling fan motors
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Does anyone know of some better cooling fan motors for the factory dual fan set-up. I like the dual fan set-up but I was wondering if anyone has ever found a higher RPM motor or higher watts or something along those lines. I have a new be-cool radiator to install I thought since I am going to have it tore down it would be nice to have better motors to install as well. If you guys know of any please include part numbers and where to get them.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: better cooling fan motors
never seen just the motor in a stronger version. You will have to go with aftermarket fans
Car: '88 Iroc
Axle/Gears: 3.45
a lot of guys use ls1 dual fans as an upgrade. i was going to go that route when i put my aluminum radiator in but didn't find a deal on one in the timeframe i needed. i went back with the stock dual fans and am satisfied with it. my temps have yet to run above 160* in mid 90's weather. if you want an aftermarket solution, everyone talks about SPAL. here's an ebay auction... you get the idea.
eightsixseven
Dec 16, 2024 01:50 PM
