fan switch help needed!
Old Jun 10, 2009 | 12:14 PM
joes407's Avatar
Car: 92 Z-28
Engine: 5.7 cam, aluminum heads, tpi upgrad
Axle/Gears: 3:42
could too much teflon tape on the fan switch sensor thats in the passenger side head cause the fan to not kick on?
Old Jun 10, 2009 | 12:31 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Re: fan switch help needed!
Possibly, the switch needs to be grounded to work. The tape may be acting as a insulator and not be giving the switch a ground. I would recommend using a liquid teflon sealant on the fan switch. If you ground the wire going to the switch does the fan come on?
Old Jun 10, 2009 | 12:44 PM
joes407's Avatar
Car: 92 Z-28
Axle/Gears: 3:42
trying to let it cool down some so i can reach in between my header tubes to unplug it.
Old Jun 10, 2009 | 01:04 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
lol, I just posted that on the Pro comp thread.
I used too much once and that caused the same thing to happen to me.
Old Jun 10, 2009 | 01:24 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i recommend a new connector and radiant wire jacket for the puny wire. plus i Teflon isnt needed, try that blue rtv stuff.its still metal on metal.,
Old Jun 10, 2009 | 02:29 PM
3rdgenmaro's Avatar
Car: 88 IROC
to keep from cluttering the other thread anymore........
yes the other sending unit works the same way. They need to be able to ground through the sensor into the engine block.
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
