Any One Use Methanol Injection / Alcohol?
Old Jun 16, 2009 | 07:12 AM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
I wanted to see if any one uses this method of cooling?
Old Jun 21, 2009 | 03:30 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Any One Use Methanol Injection / Alcohol?
hell yea, but its nitrogen you need. but in order to use the nitrogen spray, you would need an all-aluminum radiator or it will crack it. they use those on air coolers for turbo intakes. but a radiator? i dont know,,but defiantly in theory the aluminum is require because of expansion and contractions, try search up on diesel nitrogen injection air cooler kits on google. id like to hear the after effects. but if its coldness youre looking for try installing a high volume pump, 3 core radiator a lower mech tstat only with a modded hypertech thermomaster chip and really low rated thermistor fan switch.
PurelyPMD
May 5, 2016 04:57 PM
NZKnight
Oct 15, 2015 02:47 PM
racereese
Oct 10, 2015 09:39 PM
TheExaminer
Sep 6, 2015 11:40 PM
