dual fan setup
Old Jun 20, 2009 | 05:12 PM
churchofruss's Avatar
Car: 1987 chevy camaro
Engine: 350 roller/edelbrock/holley carb
Axle/Gears: 3:42 open diff
dual fan setup
has anyone ever tried using 2 of the regular single fans to make a dual fan setup?iwas thinking there maybe a possibility of it working by fabricating a frame & altering the shroud. any thoughts on it? i was also wondering if anyone has tried using 4th gen wheels on a 3rd?if you did,what mods/extras (if any) did you need?found a set that are pretty much new with nice tires for $350,just dont wanna spend it if i cant use the rims.
Old Jun 20, 2009 | 09:16 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: dual fan setup
I think you'll have a space problem with 2 single fans -- wider
than the radiator. Easy enough to confirm with a tape measure.
Wheels should be the same bolt pattern. There might be an
an offset issue, but some of the brain-trusts here on ought to
be able to clear that up. If you can take pictures of them,
mount one up front & rear, than carefully check clearances:
rotate, & turn the front wheel, rotate the rear. If you have
posi, you'll have to lift both wheels. And the obvious --
always use static safety devices (jackstands, blocks, etc.)
and if you're checking clearance, lift at the suspension, not
body/frame.
Good luck, those look like a decent buy.
Old Jun 20, 2009 | 09:58 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Re: dual fan setup
I can sell you a duel fan set up. I have a couple of them
Bubbajones_ya
Jul 6, 2024 08:32 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
