1987 trans AM with '92 chevy 305 tip cooling issues
Old Jun 23, 2009 | 06:26 PM
Tangent's Avatar
*sorry, that should say tpi in the title...*
I am trying to buy a third gen camaro or firebird and found a good one. It is an 87 trans am in decent shape, with a newer 92 305 tpi pulled from a camaro. the engine was just installed and was only driven a short ways before it sat, and now they want to sell it, so it hasn't really been tested too much. I took it for a test drive and it over heated, the temp gage went pretty high and when we stopped the coolent boiled over and steamed alittle. This was after about a 10 minute drive, we didn't get abouve 40, but did floor it to test the engine a few times. it was about 70 out. We are pretty sure the fans didn't kick in, and it is missing the air dam on the bottom. The guy said he would work with the fans to make them kick in and install an air dam. Do you guys think that would be enough? The water pump is new. The top hose seemed alittle hotter then the bottom one, but not by a huge ammount. The only other thing that it did screwy is that the oil pressure rose with the throttle, is that normal?
thanks!
Old Jun 23, 2009 | 07:01 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: 1987 trans AM with '92 chevy 305 tip cooling issues
Without the air dam, our cars fall flat on their faces. It's absolutely mandatory. Start there before replacing engine parts.
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
