should fan stay on after turn car off?
Old Jul 6, 2009 | 01:45 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
one of my dads friends who is a mechanic says this is supposed to happen. im not sure.
86 305 tpi lb9
someone took out the dual fan setup and put a oem single fan harness in.
thanx yal
Old Jul 10, 2009 | 05:57 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: should fan stay on after turn car off?
Camaro fans do not stay on when you turn the car off or if the ignition is off. There are some cars that the fans stay on, but as far as I know, camaro's do not.
Old Jul 10, 2009 | 11:02 PM
shermanwizard's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Check for a sticking fan relay. I had that problem with my '84 T/A before the relay just quit working period.
Old Jul 10, 2009 | 11:43 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
they dont stay on if you were to turn off your car and take your keys with you. but if say you were to stay in your car listenin to some tunes with the key in the "on" position, yes the fan will stay on.
Old Jul 11, 2009 | 05:54 AM
Car: 1986 IROC-Z28
thanx to all...relay is brand new
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
novaderrik
Aug 10, 2015 12:44 PM
Kaweh
Aug 9, 2015 02:54 PM
