What is this piece called?
Old Jul 15, 2009 | 10:42 AM
SSZ2891's Avatar
Just wondering what this is called. As you can see in the pictures one of the stems broke so i need a new one and dont know what to ask for. Thanks
Attached Thumbnails What is this piece called?-001.jpg   What is this piece called?-002.jpg   What is this piece called?-003.jpg
Old Jul 15, 2009 | 11:23 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: What is this piece called?
Should be a coolant bypass valve or heater control valve. Vacuum closes it when the temp slider switch for AC controls is in the cold position. When closed it prevents hot water from cycling through the heater coils. Early models didn't come with one. It could be replaced with a splice with some loss of efficiency for the AC. Part should be available at most of the chains.
Old Jul 15, 2009 | 11:31 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
You should still be able to pick them up from the local dealer or the local auto parts store.
abray1
Sep 14, 2015 08:18 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
ericjon262
Sep 11, 2015 06:07 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
