Where did I go wrong?
Old Jul 23, 2009 | 07:54 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
I'm at the end of a TPI swap into a 1993 Caprice wagon.. It's actually running!
This morning there was some condensation on the windshield so I flipped the defroster on, and the fan on high. I got lots of air moving around but no heat. So electrically The fan motor is working OK, but no heat came through.
I can appreciate why I woulnd't get A/C happening as this point as the relays haven't been pinned into the ECM as of yet.
I noticed on third gen cars there is what appears to be a manually controlled valve coming off the trottle body ( passenger side) I don't have this on my car, but figured without out it ,I'd ALWAYS have the heat on, not no heat.
I thought the water flow should see a cycle from throttle body to heater core back to radiator to radiator. Maybe I was misunderstanding the path of the coolant? What did I do wrong?
What should I be checking (and how do I check it) to make sure I have water flow, correctly plumbed, etc. I assume vacuum comes into this picture somehow since there is a vacuum valve ob the controls!
Thanks for for responses, Dave.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
