Fan Switch or Temp Switch question
Old Jul 29, 2009 | 10:30 PM
1986iroc-z's Avatar
Car: 1986 Iroc-Z
Engine: 305 bored .30 over
About 2 years ago I started my carb to TPI conversion. Ended up using an aftermarket wiring unit that needed a place for it temp sensor. I used the Cold Start Temp sensor hole since mine was not being used. I never finished he project before going to Iraq. Came back and having problems because I had to reinstall the cold start temp switch into the intake. Which switch can i pull and use - the fan switch or temp switch and not have it affect the ECM? thanks
Old Aug 1, 2009 | 12:55 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Fan Switch or Temp Switch question
The cold start and temperature sensor are the two you need on the fronrt of the manifold. Cold start is for the 9th injector only and the temperature sensor is for the ECM. The Fan switch should be placed in the passenger head (as a controller for the secondary fan if so equipped).
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
redmaroz
Aug 16, 2015 11:40 PM
TA8487
Aug 16, 2015 12:21 PM
bamaboy0323
Aug 15, 2015 07:20 AM
