would a small air leak in the radiator cause overheating?
Old Aug 3, 2009 | 11:45 PM
FirebirdFanatic's Avatar
Car: 87 Formula
Engine: 5.0 TPI LB9
Transmission: T5 5 Speed
Axle/Gears: G80 3.08?
I've been fighting an overheating problem for the last couple weeks on my 87 5.0 TPI.
When it overheated today, I noticed air/steam escaping from the passenger side of the radiator, on the side of the radiator, 4 inches down from the cap.
I understand that the system has to be pressurized, and this keeps the coolant from boiling - is this leak causing my problem? If so, any way to fix it short of replacement or welding?
thanks!
done so far: replaced radiator cap, replaced thermostat with a new 195*. Checked oil for milky appearance (looks normal).
Old Aug 4, 2009 | 04:14 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: would a small air leak in the radiator cause overheating?
i would be blaming the radiator for sure. A pressurized cooling system is critical to cooling performance. I would swap the radiator as soon as you could.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
TheExaminer
Aug 26, 2015 04:59 PM
TreDeClaw
Aug 14, 2015 06:58 PM
