Heater not Blowing like it should
Old Aug 13, 2009 | 05:31 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My heater works and everything, but it is not blowing air from the vents as much as it should. When it is on High, there is hardly any air coming out. I swapped out the ac box and blower motor for the ac delete ones, (not sure if I need to swap anything else out). What could be wrong?
Old Feb 7, 2010 | 09:02 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Heater not Blowing like it should
Any ideas?
Old Feb 8, 2010 | 08:47 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Make sure that there are no holes in your hoses. It sounds like your haven the same problem i did. I had a small hole in a hose coming off the plenum. I ended up buyin a blower motor thinkin it was that problem but I found the hose and now im stuck with an extra blower motor
Old Feb 10, 2010 | 09:24 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I checked the hose that goes to the blower motor and there were no holes in it.
Old Feb 10, 2010 | 09:49 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
I'll assume you cleaned out the donor box before you installed it.
Do you hear the blower motor through all speeds? Does it sound like it's actually blowing full speed? You should hear it change pitch as you go from low through high.
It's possible the interior doors are not moving as they should. Do you feel air moving from a vent it should not be coming out? Ie coming out the floor when you're on defrost etc?
Can you grope around under the dash and feel if the box is leaking air externally?
Old Feb 11, 2010 | 03:00 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
1. The box was cleaned before being installed.
2. I can hear the blower motor through all speeds, and it changes pitch for all of them. I am not sure how strong it should blow on high but mine feels like it should be stronger than it is.
3. I am not sure if it is coming out vents that it shouldn't be coming from, but i'll check.
4. I couldn't feel any leaks under the dash after I did some sealing to the box, and I felt a small leak around the box under the hood that I will be fixing.
Fanatic1074
Oct 2, 2015 03:47 PM
Formula8r89
Sep 22, 2015 04:24 PM
